Toshiba 2050c vertical black line
  • barber782
    • Aug 2011
    • 286
    Hi everyone,
    Got a weird one. Iv attatched a sample.
    Toshiba 2050c producing a vertical black line on printing.
    Checked the transfer belt, drum and dev. All looks normal.
    Any suggestions sound be great
    Sent from my SM-N9005 using Tapatalk
    • 23010
    Re: Toshiba 2050c vertical black line
    To me that looks like an E020 paper jam. If the paper had actually made it out of the machine, I might consider it as a quality issue. That discolored area at the right is where the paper sat in the fuser and cooked for a while, until someone removed it.
    It's fairly common to have the drive gears in the fuser unit fail, or maybe the enduser incorrectly latched the fuser.
    My suggestion is that you resolve the paper jam condition first, then see if your quality issue remains. =^..^=
    • barber782
      • Aug 2011
      • 286
      Sorryvthe yellow bit is the table behind lol. It has jammed intermittently with a fold in the middle. Not sure its related. The paper usually makes it out, and it looks like the sample shown.
        • 23010
        This piece of paper exited the machine and is fully fused? =^..^=
        • barber782
          • Aug 2011
          • 286
          Exits the machine fused. The pattern is on the transfer belt to. Iv noticed the that the dashed bits line up with the text and are slightly raised on the page.
            • 23010
            LT, long edge feed? Affecting only black or colors also? Which colors?
            • barber782
              • Aug 2011
              • 286
              Yes
              • ARMAN.MZ
                • Sep 2016
                • 100
                Originally posted by barber782
                Hi everyone,
                check black unit drum cleaner and charger just black
                Telegram ID : @armanmahzun
                • Vincent128
                  • Sep 2015
                  • 349
                  Your going to have to do a little bit more standard technician troubleshooting on this one.
                  Which tray?
                  What happens when you change orientation?
                  What happens with a different tray?
                  Does it do it from the bypass?
                  What are your PM counts?
                  Inspect paper switching gates and for toner buildup/burrs/cuts.
                  Inspect fuser entrance and lower separation plate for toner buildup.
                  • xeclectron
                    • Sep 2016
                    • 10
                    Try swapping main charge units over, could be a hairline crack in the housing. This is to cause me all sorts of weird issues.
                    Sent from my SM-T805 using Tapatalk
                      • 23010
                      Yes
                      "Yes" to what? =^..^=
                      • barber782
                        • Aug 2011
                        • 286
                        Long edge feed and black only
                        • didi2005
                          • May 2011
                          • 401
                          Since the problem is only happen on K-PU, swapping main charger unit or whole set drum unit is a good way to narrow down the issue.
                          Inspect the main charger electrode whether is out of position due to broken rear terminal.
                          • ShonRipz
                            • May 2017
                            • 33
                            Go to user tools -admin - and print a color calibration chart and upload the result into this thread. Seeing that sheet could really help troubleshoot this issue.
