4540 size detection
  • tnrtt
    • 156
    4540 size detection
    Get message saying to use ADF when you attempt to copy off glass. Replaced size sensors and scanner PCB
    • 23009
    Re: 4540 size detection
    How dirty/damaged is the matt? =^..^=
    • tnrtt
      • 156
      It's fine. Won't even let me copy with the ADF up. Tried with paper covering the entire glass. Even when I don't get the message, APS isn't working. Not defaulted to duplex. Current firmware.
      • seansbar
        • Dec 2010
        • 198
        I had that same thing once on that same model. Ended up being the ADF open/closed sensor went bad. The one I experienced is the sensor near the scanner carriage home sensor. This model seems to experience a lot of failed sensors
        • tnrtt
          • 156
          Thanks seansbar. That was the ticket.
          • seansbar
            • Dec 2010
            • 198
            Glad to hear.
