Toshiba 6530c double image one side
  • gideon
    • 283
    Rear side have double image and smears (and dirty back side of the paper), only on cardstock 110lb, doesn't have any problem on plain paper.
    The Fuser springs are stretched all the way. The roller and belt are not new but visually clean.
    Any idea?
  • clint@clintsimonsen.com
    • 125
    Re: Toshiba 6530c double image one side
    Try setting it to a Thick stock setting. And check the thermistors are clean. Check the lamps too
    Sent from my Nexus 5 using Tapatalk
    • gideon
      • 283
      Setting is on the max, 150lb, thermistor etc are ok.
        • 23009
        110# Bond? Offset? Cover? Tag? Index? Points? GSM? Cardstock is a generic term not describing any specific kind of paper.
        You must know that there are different ways to measure paper weight. =^..^=
