Toshiba ES 282 machine with alignment issue
  • raveendrala
    • Oct 2016
    • 80
    Hello
    I got Toshiba ES 282 machine with alignment issue .
    Any help would be great.
    Thank you
  • didi2005
    • May 2011
    • 401
    Re: Toshiba ES 282 machine with alignment issue
    What is the machine counter?
    Only happen on print from pc or copy as well?
    Happen on drawer only or bypass as well?
    Only alignment run, no paper jam?
      • 23009
      What paper size is displayed for the feed tray used? Does it match the paper? =^..^=
      • raveendrala
        • Oct 2016
        • 80
        Machine counter is 100000~
        It happened prient and copy
        All trays same result
        No paper jam only alignment run
        • raveendrala
          • Oct 2016
          • 80
          It s A4 it match with tray paper size
