toshiba e studio 355 presence of developer all over the copy.
  • atech
    • Aug 2010
    • 89
    [Misc] toshiba e studio 355 presence of developer all over the copy.
    Dear friends,
    I have a toshiba 355 with copy quality issue. The copy has presence of developer. I tried to replaced with developing unit from other machine but still the same, I also tried to isolate the problem by replacing HV board but to no avail. Some developer stick to the upper heat roller and could damage the roller. I need your brilliant ideas guys. Thanks in advance.
    • 23009
    Re: toshiba e studio 355 presence of developer all over the copy.
    I would suspect that the mag roller shaft is worn at the rear bearing. When the aluminum shaft wears, the grooves in the mag roller will start to rub the doctor blade making a horrendous noise. One tech thought that it would be a good idea to back away the doctor blade to around triple the usual doctor blade gap to get rid of that noise. The resulting extra tall mag brush acted like a sandblaster, wrecking 3 drums in as many days.
    You can rebuild the developing unit. Our company typically will replace the unit, so I haven't done it myself. =^..^=
    • riyadh hossainbd
      • Dec 2015
      • 239
      Originally posted by atech
      Dear friends,
      you can check
      1. by replacing drum
      2. check drum bious
      3.if sparke Transfer charger or main charger replace it
      • atech
        • Aug 2010
        • 89
        Thanks for your reply. Actually I test the whole unit to other machine both drum and developer unit and it worked fine. I need simulation code for drum, and mg roller bias..could you supply me with those codes.. thanks.
        • atech
          • Aug 2010
          • 89
          Originally posted by riyadh hossainbd
          you can check
          2. check drum bious
          Thanks​ for your reply.. I will try to reset the machine back to factory default..do you know simulation for factory reset? Thanks..
          • sakisvas
            • Nov 2016
            • 33
            can you upload a photo of a copy?
            • riyadh hossainbd
              • Dec 2015
              • 239
              08 >203>1 then 09 power on then press start button then power off and go ahead as machine discription
              but this will not help u
                • 23009
                Agreed. I am not a fan of factory resets. If the person doing it actually did all the required adjustments afterwards it might be beneficial, but nobody does. The factory reset simply tosses out all those adjustments that fine-tune the operation of the machine.
                • atech
                  • Aug 2010
                  • 89
                  I believe the machine had underwent several adjustment by previous technicians. aside from dusty copy caused by developer on the copy. When the copy comes out from the machine in A4 setting, there is background at the back of the copy approximately a quarter. Yesterday I tried factory reset and it seemed working..the copy became clearer and the background at the back of the copy has gone as well as the developer on the copy were gone..
                  • atech
                    • Aug 2010
                    • 89
                    Thanks a lot it really helped..👍
