e257 Blank Copy
  • didi2005
    • May 2011
    • 401
    e257 Blank Copy
    e257 previously cannot power ON, after replaced power supply unit, machine able to use, but blank print out regardless of copy/print without showing any error...
    LGC board? HVT board? Laser Unit?
  • riyadh hossainbd
    • Dec 2015
    • 239
    Re: e257 Blank Copy
    There are many reason for blank copy
    1.Drum rotate?
    2.Developer unit rotate ?
    3.main charger or transfer charger
    4. Hvt
    • copier tech
      • 8222
      Re: e257 Blank Copy
      Id check all your connections to the psb you replaced sounds like you left one disconnected
      • didi2005
        • May 2011
        • 401
        Re: e257 Blank Copy
        LGC board faulty...
        • copier tech
          • 8222
          Re: e257 Blank Copy
          LGC board faulty...
          Thanks for the update, 2 failed boards expensive repair!
