Toshiba 5540 with pink copies
  • bobe
    • Oct 2011
    • 38
    Hy
    I have a Toshiba 5540 and all the copies from ADF and glass to are coming pink( red), internal prints are looking perfect. I format HDD and update firmware, clear flags, replaced CCD and board, replaced Image Board and System Board with no look. I don't know what left to do. Thanks
    • 23006
    Re: Toshiba 5540 with pink copies
    What do scans look like? Sample? =^..^=
    • didi2005
      • May 2011
      • 401
      I encountered similar issue on e2550c, where copy colour(Full/AutoColor) via RADF/Glass came out green on whole page, but black/white no issue. Found that this happen on scanning side only, where when print colour via USB/PC no problem, calibration chart also show all 4 colours bar in good shape. So far tried updated to latest firmware, but no luck...
      • bobe
        • Oct 2011
        • 38
        I had one time the same problem and just cleanin optical and adjust adf fix it. I did not try adjustments in 08 or call Toshiba for support
