4540C cyan shading
  • tnrtt
    • 156
    4540C cyan shading
    I have a 4540 with some cyan shading. Printing is fine. Laying original on the glass is fine. Only does it through the document feeder. Cyan drum and developer were due to be changed so I changed them. Cleaned mirrors and lens. The shading occurs in the same spot with the same pattern. Sample attached. My sample upload keeps failing.
  • tnrtt
    • 156
    Re: 4540C cyan shading
    sample
      • 23009
      Sample?
      • tnrtt
        • 156
        Initially scanned at 600dpi. File too large. scanned at 300 and it went through
          • 23009
          Which is the feed direction?
          I'd like to see some of the prints of this:
          • tnrtt
            • 156
            Feed direction is denoted by the arrow half way down. Letter paper, long edge feed. Haven't run those test patterns as printing is fine. It only occurs through the ADF on full or auto color, not BW.
            Did you want the test prints run through the ADF?
            • tnrtt
              • 156
              Now that I think more about it, it has to be the ADF, since the optics are fixed. Probably rear height. Probably some buckling action that reproduces as cyan. I'll take one off another machine and do a full alignment.
                • 23009
                Sounds like sound plan.
                the reason I asked for prints is that it's very rare to get an ADF Only image quality issue. Odds are when you look at these prints you'll see the same issue that you hadn't noticed before on other less telling images.
                • gliderider
                  • May 2015
                  • 131
                  ADF height can be causing this issue if you're sure it's only happening through the ADF.
                  • tnrtt
                    • 156
                    Problem was adf height adjust. Surprised I never saw it before.
                    • rjthedj
                      There is a background adjustment for scanning that can be performed to remove this background. It is in the Service Manual and Handbook.
