toshiba estudio 353
  • payam.t13
    • Jun 2016
    • 7
    [Misc] toshiba estudio 353
    i have updated my machine with estudio 452.352 firmware. after that time my machine has stopped after 10 page print or copy and show paper jam error. anybody has estudio 353 firmware?
  • riyadh hossainbd
    • Dec 2015
    • 239
    Re: toshiba estudio 353
    this is not firmware problem, whats the code number?
      • 22999
      What makes you think that this is a firmware issue? And yes, what jam code? =^..^=
      • payam.t13
        • Jun 2016
        • 7
        jam code is related to e030.
        so when i removed paper the error code not cleared. this problem repeated very much and i don't know what to do
        some times when i do one side print or copy the image com in near edge of paper and do not stay on center of page. when i stop the operation and again start thats seems good but after any minute that problem occur again
        • payam.t13
          • Jun 2016
          • 7
            • 22999
            E030 is a power On jam. That means that at least one of your paper sensors is tripped during initialization, or you have at least one defective sensor. E030 does not identify a specific sensor.
            My suggestion is to test each sensor in 03 mode to identify which sensor is tripped and/or defective. Please read the manual on this topic. =^..^=
            • riyadh hossainbd
              • Dec 2015
              • 239
              it seems clutch motor problem. clean clutch motor
