Toshiba E-studiio 457 CDF0
  • DATGAGNON
    • Dec 2017
    • 9
    [Error Code] Toshiba E-studiio 457 CDF0
    Tthis machine went down with the CDF0 error code and I checked the connectors and wiring between the mot2,lgc, and oct boards. I also removed to boards and checked for visible damage. I tried a spare working offset gate motor to no avail. I was hoping someone could offer assistance, I probably have overlooked something simple.
    • 22927
    Re: Toshiba E-studiio 457 CDF0
    The main things that happen to those shifter sections are that they warp badly due to fuser heat. And when you install the exit section you have to align the linkage between the drive motor and the sliding section.
    The best thing that you can do is order up the shifter assembly, then make sure you get the linkage aligned. I've come up with some mods, but they're hardly worth the trouble on an old warped unit. =^..^=
    • gliderider
      • May 2015
      • 131
      Sometimes it can be as simple as checking to see if the jogger slides smoothly from left to right. The bushings can gum up and severely restict the movement of the jogger. Considering that it is a 457 series it I would hope that the jogger would not be in as bad a shape as the older previous series.
      • DATGAGNON
        • Dec 2017
        • 9
        The jogger moves freely and the unit is not warped, is there a chance it is a bad sensor and is there any way to test the sensor? Also thanks for your responses, I am a rookie copier tech having to learn the ins and out of machines made by 5 manufacturers with no guidance.
        • gliderider
          • May 2015
          • 131
          I have never had to replace the sensor on the jogger assy. Not to say that it could'nt be bad. I would also check your connectors again and make sure no pins are bent. You should try and get a service manual for this series if you are going to be regularly working on them.
          • DATGAGNON
            • Dec 2017
            • 9
            I have the service manual and I checked all the connectors from the exit to the boards.
              • 22927
              If it moves freely it's not linked to the motor. =^..^=
              • DATGAGNON
                • Dec 2017
                • 9
                It is fixed, thanks for the advice. I cant believe I had overlooked something so Obvious. My first month repairing office equipment has been a whirlwind of confusion and frustration.
                Last edited by DATGAGNON; 12-14-2017, 05:38 PM. Reason: Simple to Obvious, a tribute to blackcat
                • arnh79
                  • 464
                  Please share what it was. We've all done stupid mistakes over the years and sharing them with others could help somebody avoid the issue down the line.
                  Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
                  • gliderider
                    • May 2015
                    • 131
                    It can be tough when you're first learning, especially when you feel like you have been thrown into the deep end of the pool. Everyone who does this for a living is constantly learning and sometimes relearning the same things. But, making mistakes is how we all learn. Hang in there!
                    • DATGAGNON
                      • Dec 2017
                      • 9
                      The offset gate motor was not in the notch on guide slide. I won't be making that mistake again.
                      • gliderider
                        • May 2015
                        • 131
                        Usually what I do is slide the jogger all the way over to the right and then move it back to the left about an 1/8 of an inch before carefully placing the turn guide assy back on top of it.
                          • 22927
                          The position gliderider describes is about the only position that you can see what you're doing, through a small gap. That's how you'll find that position: " ... oh, there it is!"
                          It sounds like you've got a great attitude. Keep it up and you'll go a long way. =^..^=
                          • Blizzoo
                            • Aug 2013
                            • 594
                            Or the safer way to do it is to take the inner cover off ( the one above the exit tray mounted on exit unit) before fitting the exit unit and put back the cover after all is in place.
                            I always learn from my mistakes and somehow is the easiest way for me to remember these moments.
                            • DATGAGNON
                              • Dec 2017
                              • 9
                              That is exactly how I made sure they were lined up, The CDF0 is fixed but they called back today because of faint images of the previous page being printed on the following page. Job security woo hoo.
