toshiba e45
  • smiley
    • Aug 2008
    • 615
    toshiba e45
    hi friends i have a problem with my e45 there a grey back ground and uneven line on the left side of the copy.first i try to change the cleaning blade but nothing change then i think maybe the drum reach it limit then i try the drum assy. to other machine then the copy is fine then its not on the drum assy.i change laser unit but nothing change on copy.both print and copy has the back ground.what i need to do. please help me.
    there is no glory without sacrifice
  • Baphomet
    Copier Technician
    • Aug 2008
    • 293
    I'm not sure what you are calling the left side. If you are referring to the trailing edge of the paper, and the fuser was recently worked on you might have the two white drive gears on backwards. That would cause the trailing edge to smear across the drum once the leading edge reaches the fuser nip.
    • smiley
      • Aug 2008
      • 615
      thanks for the reply baphomet. its not at the trailing edge. if you have a letter size in landscape position its on the half side of the copy.
      • Baphomet
        Copier Technician
        • Aug 2008
        • 293
        Thanks for the clarification. You know, the only other thing I can think of (and it's a long shot) would be the T/S assembly. When the separation wire breaks it will not pop a code, but depending on what the broken wire is touching you can get some pretty strange copies. You might want to take a close look at it. Anything else takes me back to the process unit ... which you have already eliminated.
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1891
          Yep, sounds like high voltage arcing. Check drum, connections, & frame in rear for broken plastic where high voltage could leak. Hope that helps.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • smiley
            • Aug 2008
            • 615
            thanks guys i going to try.and i let you know what the result. again thank you soo much.
            • ToshibaTech
              • Apr 2007
              • 580
              The backgrounding could be poor developer bias. Make sure the leef spring under the developer is in good shape and will make contact with the developer unit. Sometimes they get hung when pulling the developer unit out and it could be mangled. Also if you look at where the line is on the "left" side of the paper does it line up with a buffed looking area on the drum? If so it might be the mag roller bushings are shot and causing the developer brush to buff the drum. This usually happens towards the rear side of the machine. Just a couple of shots in the dark. HTH
              I will not give you service manuals or firmware.
              • smiley
                • Aug 2008
                • 615
                if i copy only one page its fine when i do multiple copy the background apears.
                • Baphomet
                  Copier Technician
                  • Aug 2008
                  • 293
                  Have you checked the quenching lamp?
                  • minhkhanh
                    • Oct 2008
                    • 60
                    I think that is Develop hightvoltage problem, may be low. Let"s try 05/205
