tosh 557 f-111 code
  • cpjim
    • May 2015
    • 47
    tosh 557 f-111 code
    have a tosh 557 with a scanner response abnormality ( f-111). the book leads us to the sys board and main board, we replaced both. also tried the power supply , hard drive and scanner driver board. no matter what we do the copier always shows f 111 shortly after coming to ready. has anyone got any ideas? thanks in advance.---jim
    • 8228
    Re: tosh 557 f-111 code
    Can you put the machine in 03 mode, see if the output commands for turning
    the scanner motor, lamp on/off work?
    That would at least tell you if there is communication between the boards.
    Any chance the system board was replaced and the jumper wasn't set correctly?
    Have you reseated the NVRAM?
      • 23009
      Harness? Firmware? =^..^=
      • cpjim
        • May 2015
        • 47
        the scanner does not move in the 0/3 code and the exp lamp does not come on. sys board was take off of a working 557, reset all chips at least twice,and hard drive and firmware has been replaced... if it helps, this might have happened after a power outage, thanks again for the help. it goes through what appears to be a normal warm up, then when the ready comes on a relay clicks on the power supply and it codes f111.
