4520c losing IP address
  • Fattdaddy
    • Aug 2012
    • 38
    Cus. called to report this problem. Said it has happened three times in the last couple of days. Won't be going until Tues. but if anyone has an idea I would appreciate it. I have none.
    • 23009
    Re: 4520c losing IP address
    I had this on a Kyocera KM-5551ci, losing the IP address typically (3) times a week. Changing the main controller board solved this issue.
    Or it could be something a whole lot simpler. Let's say the eS4520C is set to DHCP, the drivers are directed to an IP address, and they shut the machine off every night. The DHCP server could re-assign that original IP address to something else, and assign a different address to the MFP. That leaves you with three possible solutions:
    1) Don't shut the copier OFF.
    2) Assign the MFP a static IP address outside the range of DHCP.
    3) Assign the hostname as port in the drivers (assuming that DHCP is functioning correctly).
      • 8228
      Unplug the network cable. Ping the copier's IP address. If you get a reply, there is another device on the LAN with the same IP address causing a conflict with the copier.
      Assign the copier a static IP address. Change the IP port on each PC printing to the copier to the new IP address.
        3) Assign the host name as port in the drivers (assuming that DHCP is functioning correctly).
        i have NEVER had a good response from IT when asking " Why are the printers set for DHCP and not STATIC" it's so much easier when they are set for Static IP
        • Fattdaddy
          • Aug 2012
          • 38
          So this is what I have: The machine is set to a static IP. When you reenter the IP it prints fine. When the IP is gone it is all "0"s. The mask and gateway still have their values. Only the IP is gone. Could a firmware update help. Where is the address stored?
          • Blizzoo
            • Aug 2013
            • 608
            From this point is the customer's IT problem if they have one, another device on the network is picking up your IP.
              sounds like you have a network issue... not machine. I would look at routers and server address/config. UNLESS you have network credentials .. toss it back to their IT dept.
                • 23009
                So you end up with something like this?:
                Static
                0.0.0.0
                255.255.255.0
                192.168.1.1
                Three possibilities:
                1) HDD. Are you getting corrupted addressbook entries also? Any Fxxx codes? You might try a re-format and reload firmware.
                2) SRAM
                3) or System Board.
                • Fattdaddy
                  • Aug 2012
                  • 38
                  Blackcat that is what I get. I couldn't figure what is making ip go to "O" if it is a conflict issue. Will try a firmware update and see what happens.
                    • 8228
                    To state the obvious, the e4520c is an old box that is really not worth putting parts into. Time to upgrade the customer into current technology like a shiny new e4505AC.
                    • lazymangr
                      • Feb 2017
                      • 115
                      definately is an ip conflict. try using other ip
                      • Fattdaddy
                        • Aug 2012
                        • 38
                        I would like to go with an ip conflict but how to explain the ip going to all "o". That's the come back I get from their it guy.
                        • Blizzoo
                          • Aug 2013
                          • 608
                          Have you tried to initialize the Nic 08-693? Check if you have 08-1440 set to 1 for IP conflict detect.
                          • arnh79
                            • 468
                            Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
                            • Fattdaddy
                              • Aug 2012
                              • 38
                              If FC is pressed twice will that restore the ip or does it have to be manually reentered?
