i need e-Studio 356 Sram Backup
  • IcedHeart
    • May 2012
    • 10
    Hello there
    I need the SRAM backup of the e-studio 356.
    Device is not ADI disk. So if you have an e-studio 356 machine that uses regular disk and you can send a SRAM backup and send it, I would be very happy.
    by the way i apologize for my bad english
    edit : i need only 356, not 356SE
    • 22999
    Re: i need e-Studio 356 Sram Backup
    Why do you need an SRAM backup? Did you clear or replace the SRAM?
    I'm guessing that you had a failure of the SATA drive, and what you really want is firmware to load to the new HDD. Can you clarify?
    • IcedHeart
      • May 2012
      • 10
      The machine which is working with the SATA disk is already broken. When I want to update by installing new SRAM, it gives F106 error.
      Because the Sram is looking for a disk. That's why I need a machine that does not use an ordinary disk to backup my SRAM
        • 22999
        So you're trying to replace a Wipe drive with a SATA drive, and you think that by backing up the SRAM you can install a different type of drive? According to the manufacturer once a Wipe drive has been installed, all future drives must be the same type.
        I've never actually seen an eS356 or any of that family with a SATA drive. All have been Wipe drives. I think that you'll find that with the latest firmware, you will need to replace the HDDs less often. A year ago I was using 2 HDDs a week. This year I use 1 HDD per month. =^..^=
        • didi2005
          • May 2011
          • 401
          Early batch of e356 is using normal SATA HDD, then replaced by e356SE with new ADI HDD...
          As what I know, SRAM used to store the information of the MFP such as serial number, counter...( *Correct me if I'm wrong )
          If HDD problem, just replace another HDD and update firmware, no need touch the SRAM...
          If the SRAM problem, u can backup the SRAM to USB, replace the SRAM, and recover the SRAM data...
          If not able to backup SRAM data, u can enter 6C mode, set serial number to the MFP...
          • IcedHeart
            • May 2012
            • 10
            I solved my problem.
            First, I thought I had a problem with hdd, so I changed the hdd cable since the problem was not solved after changing the hdd and the hdd device was working on another device.
            When I did not solve my problem, I was trying not to assume that I needed to install a standard disk because the device had normal SATA HDD. I thought that I could solve my problem with extremely high SRAM prices (500 USD per disk) in the country.
            Considering that the device wants an ADI disk due to a firmware update.
            But the problem is very simple. I changed the hdd cable is broken.
            Thank you for your help.
            and lastly, I hate ADI discs.
