E Studio 232 No Power
  • callmefirst
    • Feb 2012
    • 51
    I have a E Studio 232 with no power, the previous tech replaced fuser lamps, thermistors and power supply. I found a completely dead machine with power going into the high voltage power supply and nothing coming out, all the fuses on the board are ok. Any suggestions would be appreciated, thanks.
    • 23009
    Re: E Studio 232 No Power
    I think I would start with the basics. I would read all outputs from the power supply.
    The way it should work:
    When the main switch is turned ON, you'll get ONLY 5vdc to the logic board. Only when the logic board boots up it will send a signal to the power supply to enable other voltages. The logic board also enables the HVT to function, whether or not there are voltages present.
    So first, determine what voltages you are getting, and which you are not at the power supply. If there remains a short in the machine, that new power supply may be just as dead as the last one. =^..^=
    • didi2005
      • May 2011
      • 401
      I did encountered before e232 no power due to HVT board faulty.
