toshiba 305 firmware issue
  • ratheesh123
    • Feb 2018
    • 5
    dear friends .. i try to update firmware to estudio 305 .. it will almost finish .. atlast it needs to intialise settings . sram requires intialisation .. i am trying to selact intialise but in touch panel intialise and cancel both of them is not working anybody have solution??
  • gliderider
    • May 2015
    • 131
    Re: toshiba 305 firmware issue
    If your firmware update finished correctly, then the next step would have been to power back up in 08 and key in 9030 to initialize. SRAM initialization would have nothing to do with a normal firmware update.
    • ratheesh123
      • Feb 2018
      • 5
      but friend intialise option is not active in toch panel
        • 22994
        Does the touch panel work in normal copy mode? Is it aligned? =^..^=
