1310
  • franc99
    • Aug 2025
    I have a toshiba 1310 with bad fusing: i have changed the thermistor and upper roller but he still poor fusing. Have you an idea to solve this trouble?
  • imaginGuru
    Have you tried to change the upper fuser roller bushings as well?
    check the pressure roller springs for correct position and/or the lower(pressure)roller has no worn shaft endings either.
    if image is good but no fusing is done even though heat is present, then you have a pressure loss somewhere. there's no other thing to blame.
    • jawir
      • Aug 2007
      • 107
      Hi,
      Also don't forget to check the bush press, usually it's broken. this part is bush to hold and press the lower roller on the both side of shaft lower roller.
      regards
      • _____e03_____
        Originally posted by jawir
        Hi,
        regards
        I agree to sir jawir
