Toshiba E Studio 230
  • craigo
    • Nov 2016
    • 11
    This copier only jams after machine is turned on in the morning or sometimes when it comes out of a prolong sleep.
    When misfeed occurs it's in the fuser and mostly accordianed. Fuser claws are good as well as the springs. I have replaced the upper and lower fuser rollers. I'm mainly a Ricoh guy and stumped. Any help would be appreciated.
    Craig
  • Vincent128
    • Sep 2015
    • 349
    Re: Toshiba E Studio 230
    Machine jams after setting for a while issues are generally sticky drive sections/gooped up oilite bushings/clutches.
    I'd pull the drive section out and inspect/clean/lube, check drive pins on drum shaft, replace high low clutches and pull all the regis/transport rollers out.
    • copyguy69
      • Feb 2016
      • 94
      I would try replacing the claws anyway and check what the temp. settings are set at in power saving mode. Good luck
      copyguy69
