Toshiba e studio 4520c
  • copierlady
    • 338
    Thank you for the help with the ca00 code on this copier. Finally got the code to go away but now the copies are too red. Is there an adjustment I can do in diagnostics mode? I know I sound like a rookie, but I'm a Konica gal!
    • 23009
    Re: Toshiba e studio 4520c
    Clean the scorotrons. Clean the laser slit glasses with the wand.
    Enter 05 Mode (hold down 05 while powering up, until the 5 green function lights illuminate).
    Select 396 > Start
    Select 4719 > Start
    Select 4 Fax (test pattern is printed). Lay pattern on the glass with black blocks closest to the index and 15 blank pages on top of it. Close DF. Select 1642 > Start > OK (when finished).
    Select 70 Fax (test pattern is printed). Lay pattern on the glass with black blocks closest to the index and 15 blank pages on top of it. Close DF. Select 1008 > Start > OK (when finished).
    Hold Power button until you hear (5) beeps and machine shuts down. Press power button to power back On.
    All of this is available in a service handbook if one were to look. =^..^=
