E2050c line
+ More Options
Posts
  • didi2005
    • May 2011
    • 401
    E2050c line
    Solid black line appear when printing counter list or colour print. The back of counter list also got similar line, except not so solid. Same line found on 2nd transfer roller. I've cleaned 2nd transfer roller but the line come back when print, checked k pu main charger & drum, checked transfer cleaner blade, no line on transfer belt, no line on fuser unit....Any sugesstion?
  • Blizzoo
    • Aug 2013
    • 605
    Re: E2050c line
    Swap K with Y drum unit and do some tests, you may need to replace the transfer belt cleaning blade, check the bushings if gum up and hard to turn on the ends of the tbu cleaning facing roller.
      • 22997
      Re: E2050c line
      It's not always easy to tell where that line is coming from, and color is not always conclusive. Here's an example:
      Primary transfer waste toner is usually between brown and purple colored, but if your enduser is printing a very high percentage of black, your primary transfer waste toner will be mostly black too.
      A simple visual inspection should help you find your line:
      1) Start by examining each drum for poor drum cleaning, or a small fiber stuck to the blade focusing the primary charge in one area. Rotate each drum manually to see if the drum continues to clean well.
      2) Check that the primary transfer belt is cleaning properly. Something as simple as a hair dragging along the primary transfer belt can create a line like this. The reason you see the toner on the backside of the paper is because not only is the line created in the latent developed image on the primary transfer belt, it is created between the the image areas, and continues to transfer to the secondary roller between pages, then is transferred to the backside of the paper.
      3) Actually the fuser is the most likely cause. Check the pressure roller where the claws contact it. My guess is that the teflon is torn through. As a result, small amounts of residual toner from the heat belt transfer to the pressure roller in the torn areas, then stick to roller until paper picks it up.
      • didi2005
        • May 2011
        • 401
        Re: E2050c line
        Replaced 2nd transfer roller, transfer belt cleaning blade, swapped k drum unit, still the same line appear...
        When printing counter list, before reach fuser i stop the machine, found the line appear on k drum unit & partial transfer belt unit...
        Suspect k print head issue, visually checked & cleaned....
        • gliderider
          • May 2015
          • 131
          Re: E2050c line
          It appears that the problem is a mechanical issue verses an electronic issue since the line extends to the edge of the paper. I don't think the printhead is the issue. Is the transfer belt turning smoothly? Have you disassembled the transfer belt and checked it? There were numerous updates to it.
          • didi2005
            • May 2011
            • 401
            Re: E2050c line
            Found that the line appear on k drum, after print out, no more line on transfer belt which mean the cleaning is good...
            Same as drum unit, after print out no line appear on drum, which mean cleaning ia good...
            Below is the 18fax charts, all colours with solid black line...
            I dont have alcohol, wonder can use contact cleaner to clean print head?
            • gliderider
              • May 2015
              • 131
              Re: E2050c line
              You should'nt need anything stronger than water.
              • Blizzoo
                • Aug 2013
                • 605
                Re: E2050c line
                I have been once in the situation when I had a moment of 'something is not right' caused by a piece of hair of someone in the office after a PM on a 6570c, I took apart the main charges a few times plus other things, I've done the tests just in 04 Start on halftones and those lines were as the printed color, I was amazed when found that.
                I didn't seen any damaged printheads in these machines but worth a try to check the flat cables on each end of the printheads.
                  • 22997
                  Re: E2050c line
                  I haven't seen any bad LED printheads on any of the Weisshorn series. If it was a dirty printhead you would be seeing voids, not lines.
                  I suppose it wouldn't do any harm to re-seat the LED array ribbon cables ... keep in mind that it's very easy to damage ribbon cables. =^..^=
                  • didi2005
                    • May 2011
                    • 401
                    Re: E2050c line
                    I reseated the flat cable...still the same...
                      • 22997
                      Re: E2050c line
                      Only one? There should be four, minimum. =^..^=
                      • didi2005
                        • May 2011
                        • 401
                        Re: E2050c line
                        Based on my experience on toshiba models, is very fagile,do not simply touch unrelated parts,haha.
                        Anyhow, problem solved after replaced whole led unit, below is the problem led, nothing wrong with the k print head surface...
                        • Blizzoo
                          • Aug 2013
                          • 605
                          Re: E2050c line
                          Interesting fault, I would appreciate if anyone has an explanation of how does the K drum was charged and LED ON to cause that line. Thanks for letting us know the fix.
                          • didi2005
                            • May 2011
                            • 401
                            Re: E2050c line
                            I think the faulty print head keep beaming/charging the drum causing the solid black line...This may be why the line stick on the 2nd transfer roller.
                            PS: Without the harness holding jig, we can tide up the connector & flat cable using tape, can be take out easily. But when install back the led unit, one person very hard to get it done since the hole not big, luckily customer willing to help pushing in the led unit while I get the connectors pass the hole
                              • 22997
                              Re: E2050c line
                              Yes disassembly takes a while but is not difficult. It really does take two persons to get the wiring routed back through the slots.
                              If I were to make a guess, I'd say that the circuitry that controls the black LED is turning ON a group of LEDs continuously. It's the only explanation. =^..^=
