good day guys my friend want to disable the toner chip for this machine because he need a compatible toner but evrey time he get to 08 695 and press start it goes back to ad. instead of 1 or 0.
estudio 223
Re: estudio 223
After setting 08-695 to a 0 you need to press the Interrupt key to lock in the value you changed. -
Re: estudio 223
es 223 have not code 08 695 this code working only model before es 223 like es 163 es 166 .some solutions-> you can change 08 971 is to 3. but cant disable toner chip only can toner mark remove. sorry for my englishComment
Re: estudio 223
Put compatible toner in Toshiba MFP is a disaster...especially newer type where the toner comes with chip...
I wonder how the chip work?
If I have 2 genuine toner cartridge with chips, can I just use back the chips? For example after toner A finish, I insert toner B, when toner B finish, I insert toner A? Will it work?Comment
