estudio 223
  • smiley
    • Aug 2008
    • 611
    estudio 223
    good day guys my friend want to disable the toner chip for this machine because he need a compatible toner but evrey time he get to 08 695 and press start it goes back to ad. instead of 1 or 0.
    there is no glory without sacrifice
  • gliderider
    • May 2015
    • 131
    Re: estudio 223
    After setting 08-695 to a 0 you need to press the Interrupt key to lock in the value you changed.
    • smiley
      • Aug 2008
      • 611
      Re: estudio 223
      hello friend thanks for the reply but evry time we put 08 695 the machine goes back to ad.we cannot change it to 1 or 0.
      • prabhath731
        • Oct 2017
        • 5
        Re: estudio 223
        es 223 have not code 08 695 this code working only model before es 223 like es 163 es 166 .some solutions-> you can change 08 971 is to 3. but cant disable toner chip only can toner mark remove. sorry for my english
        • didi2005
          • May 2011
          • 401
          Re: estudio 223
          Put compatible toner in Toshiba MFP is a disaster...especially newer type where the toner comes with chip...
          I wonder how the chip work?
          If I have 2 genuine toner cartridge with chips, can I just use back the chips? For example after toner A finish, I insert toner B, when toner B finish, I insert toner A? Will it work?
