es 450 problem loading hdd firmware
  • tmw
    • Dec 2013
    • 211
    Hello.Before, I have successfully replaced and loaded firmware on to new hard drives, but now it wants to confound me. I'm using a 2 gb flash usb, is formatted FAT, and has 450 firmware on it. I've tried two different usb s. I have also tried different hard drives and system board. When I go into the 4 9 mode, it shows either a line of numbers going down, or will say 'firmware up mode...initializing now'. Either way, it will hang up at that point all day if you let it.
    At the risk of sounding like my customers, we've used these same usb s before and it has worked. I need to get someone going with a new hard drive. If nothing else works, does anyone know if they sell hard drives with firmware on & ready to go ? I appreciate any suggestions anyone would have. thanks.
    • 22599
    Re: es 450 problem loading hdd firmware
    Have you included the mentos file on the root of the drive? Many of the older models need that file. =^..^=
    • tmw
      • Dec 2013
      • 211
      Yes, that file is included.
      • didi2005
        • May 2011
        • 401
        I wonder what is the capacity of your new HDD...This e450 models comes with 20GB HDD if I'm not mistaken...
