toshiba e-studio 3530c off line
  • bruce 49dcs
    • Jan 2017
    • 140
    this machine actually belongs to my IT guy and he swears the nic is bad
    the machine goes off line after some time not sure how long but they say when it does they cant ping it or anything and only comes back after rebooting the machine
    i did 08-693 the ip address is static im wondering if there is an 08 setting for the nic to time out or not time out maybe a bad driver any ideas would help
    thanks in advance
    bruce
    49 dollar copier service
  • didi2005
    • May 2011
    • 401
    Re: toshiba e-studio 3530c off line
    If NIC faulty, reboot machine suppose still no connection...
    U can try bypass the network, hook up a laptop and perform ping test non stop and prove to the IT guy...
      • 22999
      You want to know how many bad Toshiba NIC cards I've seen? None ever.
      Connect it to your laptop via a known good crossover. Set up two static IP's. Print, Scan, Ping, view the webpage, whatever.
      My guess is that there's a dupe. =^..^=
      • Scott
        • 195
        Only seen 1 bad NIC card since copiers went digital. IT guys are the toughest guys to prove that to, especially if they diagnosed it. IP conflict??
