Toshiba HDD w/ wipe technology
  • RandyW
    • Jan 2013
    • 213
    I was curious if you can put a HDD with the same specs in a Toshiba machine but without the wipe technology.
    MQ01ABU032W would be the one I was interested in.
    Some Okidata machines use them.
  • gliderider
    • May 2015
    • 131
    Re: Toshiba HDD w/ wipe technology
    If the Toshiba came with a wipe techonology drive than you should replace it with one. That being said, Tech bulletin TSB 178 Rev. 08 lists different combos of HDD,s for each model line.
      • 23010
      In defense of the Wipe Drives, they seem to be lasting much longer now that the firmware has been changed. Up until about a year ago I was using 10 of these drives a month. Nowadays I change maybe 1 drive a month, often wrecked by power outages, yanking out the plug, or improper shutdowns. =^..^=
        • 8322
        If you are asking, can I successfully replace an original Toshiba MQ 320 GB drive with a similar 320 GB drive from a different vendor, the answer is no.
        It might be tempting if you do not have quick access to a Toshiba original MQ drive or you are trying to save some money but it will not work.
        Best practice is to always have a Toshiba original MQ drive in stock. They do go on back order once in awhile or your customer is in a panic and expects you to fix the copier under a four hour service response contract.
        I also do not think you can pull the drive from a Toshiba copier in stock and put the drive in a different copier as this violates the Secure HDD built in protections when the HDD sees a different Mac address.
        With the eBN product line, I have seen a dramatic decline in HDD failures compared to the previous eBX product line.
        • didi2005
          • May 2011
          • 401
          I remember all those e2550c series came with 8GB SSD drive, where we need to replace 320GB ADI HDD and enable some 08 codes...
          • Vincent128
            • Sep 2015
            • 350
            Yes you can, you have to format the drive which is what creates a new ADI Key then load firmware.
            • RandyW
              • Jan 2013
              • 213
              Yes that was pretty much it. There was a big difference in prices looking around on eBay etc...
