e-studio 5506AC print problems
  • sakisvas
    • Nov 2016
    • 33
    Dear friends,
    I have a problem with a e-studio 5506AC. i have lines in printing , in all image units cmyk ... i print with 04- 237 and the lines are for all colors in the same point.... I have clean drum units , transfer belt unti, 2nd transfer roller. I calibrate the machine but the problem not solved.
    The machine has 150000 colors pages and 45000 b/w .
    can you help me please!!!
  • Blizzoo
    • Aug 2013
    • 608
    Re: e-studio 5506AC print problems
    Clean the main charger units and grid's all colors, replace the K charge grid, clean laser slit glass and do a test.
    • sakisvas
      • Nov 2016
      • 33
      I have clean all main chargers ,grids and laser slit glass... I put the yellow charger unit in black drum for test, but the problem not solved.. I do not replace the charge grid..
      thank you
      • Thayer
        • Dec 2017
        • 107
        How does the fuser look?
        • seansbar
          • Dec 2010
          • 198
          Actually, in my opinion that is not too bad. But if your customer is picky, I would start by replacing all 4 charge grids, they get covered in ozone residue so fast. I would also double check the laser slit glasses.
          • sakisvas
            • Nov 2016
            • 33
            The fuser is ok... I stop the paper before the fuser and the image has lines..
            • sakisvas
              • Nov 2016
              • 33
              Thank you, i will replace the grids .
              • Service Call Assassin
                • Jun 2023
                • 4
                Has this issue been resolved? I have a customer who runs a printshop. Half tones in my opinion look comparable to other mfps with similar age and series. The problem is when he try's to run custom 70% cyan/ 30% magenta. Those lines become very visible. I'm sure Toshiba would say its within spec but he is a long time customer and not going away anytime soon. I too have cleaned the inside of the laser, replaced ITB, did pm on all process units including new steel grids on all colors. No luck.
                • sappa12
                  • Sep 2023
                  • 57
                  this one is tricky to fix, if you have the same pattern on all colors its usualy transfer belt isue or bias isues with ctr1. i have one 7506 with 3,5M copies and last time i clean all tr. belt framework, put new belt on,new drums,grid+pin chargers,clean glasses on laser unit and still didnt get the quality that i hope to get
                    • 8213
                    Ozone residue on charge grids is a new one to me.
                    What would that look like?
                      • 23009
                      The typical corrosion you would see on the smaller models ... I think that's what they mean. I have used steel wool on the grid in a pinch. Naturally you have to follow the lines of the grid, or you can destroy it, and it's not a long term solution. =^..^=
                      • Allit002
                        • Mar 2024
                        • 2
                        Filter or replace the Dev
