Toshiba Error E190
  • qcoffice
    • May 2018
    • 7
    [Error Code] Toshiba Error E190
    Hi guys, i got a Toshiba es455 with an error E190. Papers not picking up from LCF. Needs new roller kits?
    or something else needs to replace? I did cleaned all the rollers but still E190.
    • 23010
    Re: Toshiba Error E190
    How many clicks on the LCF rollers? Near yield? Any flats? =^..^=
    • qcoffice
      • May 2018
      • 7
      About 15,000 pages. The rollers look good. The rollers not picking up papers. Thanks
        • 23010
        I haven't seen it on the KD-1026 ... but on the very similarly constructed KD-1024 I've seen a few things:
        1) One of the plastic alignment posts at the rear of the feed unit shears off. The feed unit loses drive.
        2) The previous tech disassembling the paper deck drive unit installs the bronze bushings with the collars to the outside of the drive pack. The bushings are supposed to be installed collars to the inside of the drive pack. Maybe I have a photo or 3 ...
        Broken clutch wiring
        Broken post
        Repaired post
        Bushings wrong
        Bushings right
        All these paper decks are a Ricoh design, and very similar. =^..^=
        • qcoffice
          • May 2018
          • 7
          [ATTACH=CONFIG]39646[/ATTACH]
          Broken post
          [ATTACH=CONFIG]39650[/ATTACH]
          Repaired post
          [ATTACH=CONFIG]39649[/ATTACH]
          Bushings wrong
          [ATTACH=CONFIG]39647[/ATTACH]
          Bushings right
          [ATTACH=CONFIG]39648[/ATTACH]
          I'm going to replace the paper feed kits again. Hopefully It's OK. Thanks
          • qcoffice
            • May 2018
            • 7
            I really hated KD-1024 and KD-1026.
              • 23010
              They seem to work fairly well ... other than the issue listed. =^..^=
              • jamesyboy
                toner monkey
                • Jul 2010
                • 188
                check the interlock switches on the ped door are ok and being switched correctly
                • qcoffice
                  • May 2018
                  • 7
                  OK. I replaced all the rollers but still E190. Here is what i saw: the feed and sep. turning but pickup roller was not. What causes the pickup roller not turning to pick papers up? I haven't seen this before. Thanks
                    • 23010
                    There's an idler gear that rides between the feed and pickup rollers. If the gear is gone, or the pick roller is not properly clipped on, it won't turn.
                    None of the rollers will turn if the wire harness is broken to the clutch, like in the previous post. =^..^=
                    • qcoffice
                      • May 2018
                      • 7
                      well,well,well. I swap the LCT with a working one and now i got a different problem. When i try to made 5 copies, the first 2 come out OK, the next 3 the image just shifted to the back by 1/4 inches. ADF or glass same problem. Tray 1 and 2 OK. Man, i haven't seen this problem before. Any ideal guys? Thanks.
                        he just told you to pull the feed units and check to see if the pins are broken?
                        " to do the same things over and over and expect a different result is the definition of insanity"
                        • qcoffice
                          • May 2018
                          • 7
                          Well, this is a different LCT with a different problem. Did you read my posted?
