Toshiba E456 stuck on checking system.
  • ameritech
    • 96
    I have a toshiba E456 stuck on checking system. I Replaced the "wipe" hard drive not the regular sata. Format drive, format admin password. Update firmware went through. Cannot
    get into mode 08 to initialized. Can this be a board issue. Thank you for your help.
  • Luther
    • May 2006
    • 682
    Re: Toshiba E456 stuck on checking system.
    Does this machine have a fax?...if so disconnect it and see if it boots, or unplug one option at a time , i had the same thing with the fax being bad
      • 23003
      Is it a new Wipe Drive? The "Checking System..." message is almost always the HDD.
      I think that I'd try formatting the drive one more time and try again. If it still gives the message, I'd try a different drive. It could possibly be a System Board problem, I'd say that it's 75% drive, 20% system board, 5% ... something else. It sounds like you've got the procedure correct.
      • didi2005
        • May 2011
        • 401
        ADI HDD--> SATA cable-->SYS board
