Toshiba es 306 Help me fix f901 error
  • minhkhanh
    • 60
    [Dead] Toshiba es 306 Help me fix f901 error
    Err code f901, " Engine speed error: The speed information of the LGC
    board is damaged."
    LGC board run ok when run on another e 356 machine and install firmware, SYS board is not.
    Is there a way to fix the above, if not replace SYs board
    Thanks a lot
  • laitang
    • Nov 2012
    • 627
    • minhkhanh
      • 60
      Re: Toshiba es 306 Help me fix f901 error
      Still need help .....
      • Blizzoo
        • Aug 2013
        • 607
        A 306 LGC Board doesn't work in a 356 machine.
        • minhkhanh
          • 60
          Sorry, i created wrong topic. Toshiba 356 .
          E356 LGC & sys board
          • nhatthuc0000
            • Dec 2007
            • 44
            Good luck to you!
              read forum rules...posts/comment to be made in ENGLISH
