Toshiba 5520c close duplexing unit cover
  • mntech
    • Aug 2010
    • 250
    Door switches check out, fuses are good. Any help much appreciated.
    Another company had a tech out, they said they replaced all the door switches and the dc power supply.
    Sent from my SM-G955U using Tapatalk
  • mntech
    • Aug 2010
    • 250
    Re: Toshiba 5520c close duplexing unit cover
    One thing I noticed is the only other door that will display a "cover open" message is the duplex outside cover, nothing shows with adf, front door, finisher, lower right door. Not sure if that is abnormal.
    There isn't a third duplex unit door switch that I'm not seeing is there? I only found the 2 120v safety switches, one on frame towards lower back side of right side, and the other up in front next to fuser that the bridge unit also actuates?
    Another thing I noticed is fans come on when I actuate the upper front switch.
    MN tech
      • 23006
      The thing that I noticed was that the switch itself isn't the problem, it's the actuator lever that operates the switch:
      From the database:
      "Call For Service C471". Right side lower rear interlock is not made during initialization. One of the shoulder screws is backed out, letting the actuator swing aside. Re-position right side lower rear interlock actuator. Re-install or replace shoulder screw. Reset error in 08-400.
      • mntech
        • Aug 2010
        • 250
        I appreciate the reply black cat, but I have manually actuated the switches and verified voltages when doing so, close duplex unit message never goes away
          • 23006
          That answers my next question. If the 24v supply voltage to the interlock is missing you can get the same result.
          Sorry, that's all that I've got. =^..^=
          • mntech
            • Aug 2010
            • 250
            I haven't been onsite yet to verify this, but it looks like it may be a sensor instead of interlock switch that is detecting the duplex unit being open.
              • 23006
              Perhaps a disfunctional Sharp 73 sensor? We've all seen plenty of those, all over the machine. =^..^=
              • mntech
                • Aug 2010
                • 250
                Sure enough, didn't realize there was a gate in what I would call the duplex inverter, that has a flag with a photo sensor that detects the duplex unit is open/closed... Sneaky little bugger is a bit hidden, threw me off with the other two interlock switches. Once I realized it was there... Pretty easy to correct, 2 screws 1 harness the inverter section comes out, just had to pop the sensor back in place and a dab of super glue for good measure.
                -mntech
                  • 23006
                  -mntech
                  Congratulations on your success! Thanks for posting back. =^..^=
