Need updated firmware E-Studio 520 (rebranded as Oce Imagistics im5530)
  • Zorg
    • Jul 2018
    • 7
    [Misc] Need updated firmware E-Studio 520 (rebranded as Oce Imagistics im5530)
    Have an Toshiba E-Studio 520 that is branded as an Oce Imagistics im5530. It needs a firmware upgrade.
    It utilizes the SMBv1 protocol ONLY for scanned document retrieval.
    The SMBv1 protocol is a MAJOR SECURITY RISK for Ransomware!
    The goal is to eliminate SMBv1 from the entire network. Alas, this copier which works perfect is online and the scanner function is needed!
    I need a firmware upgrade or a workaround.
    Any suggestions most gratefully appreciated!
    • 22703
    Re: Need updated firmware E-Studio 520 (rebranded as Oce Imagistics im5530)
    How about FTP, or scan to the HDD?
    Two very simple non-SMB choices. =^..^=
      • 22808
      if he had an old PC laying around, he could set it up to scan to folder also, then send out via email.
      • Zorg
        • Jul 2018
        • 7
        Hmmm I will check out FTP. I am unsure of the scan to HDD. I have dug pretty deep into both the estudio Network Admin Manual and the Service manual but perhaps I must dig deeper but nothing rings a bell.
        • Zorg
          • Jul 2018
          • 7
          The office has no spare pc's. They are all Windows 10 of one flavor or another except for one Windows 7 Pro (good software that does not run properly on Windows 10 but vendor is out of business) that is special purpose. All are networked with SMBv1 disabled forever.
          • jonhiker
            • 661
            does this model scan to email? that would be another solution
            • didi2005
              • May 2011
              • 401
              Try scan to E-Filing? But client pc need to install file downloader software to connect MFP and download.
              • Zorg
                • Jul 2018
                • 7
                It will only scan to email if there is a local email server. Alas, there is not.
                • Zorg
                  • Jul 2018
                  • 7
                  Does anyone know where I could find compatible downloader software?
                  Thanks!
                  • toshibaestudio
                    • Jun 2016
                    • 116
                    Thanks!
                    • Zorg
                      • Jul 2018
                      • 7
                      Originally posted by toshibaestudio
                      This is the software I install on the various computers to PRINT to the copier.
                      I will dig into this to see if I can find something to extract scans.
                      • Zorg
                        • Jul 2018
                        • 7
                        Installed software. Tried a scan and it worked. Now I need to find a way to simplify the user interface on the copier.
                        Is there a way to setup some defaults so we don't have to go through the procedure of selecting a BOX each time we scan?
                        Thanks!
                          • 7883
                          Toshiba File Downloader was very limited it's capabilities and was not widely used.
                          You are trying to make discontinued software work with a long ago discontinued copier to solve a 2018 problem.
                          If you need to scan directly to folder via SMB2/ SMB3 you need to upgrade the copier to a current model.
                          No support will be coming from Toshiba to offer SMB2/SMB3 scanning from a e520 copier.
                            • 35067
                            With Ricoh you can scan to the Document Server hen retrieve using WIM.
