es306se f901_1
  • riyadh hossainbd
    • Dec 2015
    • 239
    es306se f901_1
    is wrong firmware (updated yellow firmware instead of red firmware without scanner) the cause for f901_1 code?
    # checked all Cable
    #logic board is blue sticker, originally comes with machine
    Re: es306se f901_1
    # checked all Cable
    it is covered in the manual.... did even open it?
    • Code: F109_1
    • Description: Key consistency error: SRAM encryption AES key data damage.
    • Causes:
    • Remedy: Setting Reboot the equipment. If it cannot be recovered, reinstall the software in the following procedure. (1) Install the OS data.
    • riyadh hossainbd
      • Dec 2015
      • 239
      Re: es306se f901_1
      you mistake something, my code was F901_1
      • Code: F109_1
      • Causes:
      Sent from my vivo X7 using Tapatalk
        • 23008
        Re: es306se f901_1
        I'd have to guess that the wrong Logic Board is installed, in an attempt to make the machine faster. (Wrong Engine Speed Data). =^..^=
        • riyadh hossainbd
          • Dec 2015
          • 239
          Re: es306se f901_1
          logic board is right one and blue color sticker. logic board have not changed yet in machine's life
