Toshiba no transfer
  • copygal
    • Feb 2012
    • 23
    Toshiba no transfer
    Have an Oce 2330, light copies.
    Main charge, drum and toner good.
    It appears as it the transfer charge is not
    being applied. Looking for Toshiba 6LA85754000, transfer charge assy. This is a non profit and if possible would like to repair unit. Thanks
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    Re: Toshiba no transfer
    I'd check developer bias contact first.
    My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
    • copygal
      • Feb 2012
      • 23
      Panic stop shows a solid image on the drum.
        • 23010
        Most likely you're right about a shorting S/T unit, and I'll be surprised if you find one. It's an old machine and all our donors are parted out. =^..^=
        • copygal
          • Feb 2012
          • 23
          That is exactly what I told the customer. They were given the machine 7 years ago and have had no problems with it, until now.
