Firmware issu
  • riyadh hossainbd
    • Dec 2015
    • 239
    Firmware issu
    When Try to update Firmware, it Show an error . Model es2820c, whats the problem?
    Sent from my vivo X7 using Tapatalk
    • 8183
    Re: Firmware issu
    Is the firmware located on the root of the USB drive not under any sub folder?
    Are you trying to install V331 firmware?
      • 23006
      Re: Firmware issu
      I seem to recall getting that message when I forgot to load the firmware to the stick. It would probably be best to reformat the drive FAT32 then copy the firmware folder: 2820C_3530C and file: mentusb2.o to the root.
      You may find that it's covered in the manual. =^..^=
      • riyadh hossainbd
        • Dec 2015
        • 239
        Re: Firmware issu
        U are right, I tried to install v331. Have any problem of that Firmware?
          • 23006
          Re: Firmware issu
          It won't scan to Gmail, but that might not matter. If you're scanning to Gmail you'll want ttec364.
          • MUMMIM
            • Jan 2008
            • 125
            Re: Firmware issu
            what is ttec364 ? can you tell us to know and how can we install it
            regard
              Re: Firmware issu
              regard
              ttec364 is a firmware version/revis....
              are you a tech? you don't know how to install firmware? do you HAVE the manual? GET IT READ IT!
