toshiba e-451c f111 error
  • erikdeterman
    • Aug 2025
    I have tried everything the book says to do short of replacing the sys brd. Any alternatives?
  • Baphomet
    Copier Technician
    • Aug 2008
    • 293
    First off, confirm that the cable between the SYS and SLG isn't pinched, broken, or otherwise molested.
    Re-install or update the firmware. If the update fails at any point, replace the component associated with the failure, ie; scanner failed then replace the SLG board.
    However, the firmware might take care of the issue.
    • erikdeterman
      It only seems to act up on copies, not print jobs so I'll try slg brd first-thanx for the help!
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1891
        Friendly reminder
        Remember to only replace one board at a time. They are serialized & need to write to each other for counterfeit protection.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • mckinley
          Chief Twiddler
          • Dec 2006
          • 150
          it's the 5.1v supply too low. chances are this is happening when using the RADF by any chance? when the voltage is too low ( which is a known issue ) the radf times out when scanning originals through & throws up an F111 error, also there are some modified ruby sensors for the MR3018, but you can cut out the windows that the 2 ruby eyes look through this will stop most of the F111, but it's only compensating for the low 5.1v supply.
          you can measure the supply on the rear of the RADF, with the back panel off it, put your meter on one of the yellow wires & obviously on to earth, if the reading is below 5.1, look at the metal cover on the machine's power supply. it has 2 round holes, if you look through each, there's a variable pot. make sure to adjust the one on the left ( when looking from rear of m/c ) it sits just above a coil, so you must have an insulated flat blade screwdriver! or you'll blow up the machine & probably yourself. turn the pot anti-clockwise ( to increase the voltage ) very very slightly, it only takes a tiny movement to alter the voltage quite a bit.
          this 5.1v supply can also cause intermitant C550 errors btw.
          hope it helps.
          Happiness Is The Road.
          • erikdeterman
            hope it helps.
            I changed the slg brd and updated the scan and so far no problems
            • erikdeterman
              I have now changed ribbon cable between boards, slg, sys brds. Now leaning to power supply. I've checked the 5.1v. It happens off glass as well as adf. After reseating all power supply connectors the machine worked for 10 minutes and popped a f-111 again. Moved machine to dedicated power source and same thing! Any ideas?!?
              • ToshibaTech
                • Apr 2007
                • 580
                Good info Mckinely. I have a couple sensors I had cut the windows out in I keep in my bag in case I am out of a new one. Haven't had to use one yet, but good to hear you have had success with it. Thanks for the tip on the 5V supply I had not seen this yet and will try to remember it.
                I will not give you service manuals or firmware.
                • TTL
                  • Dec 2008
                  • 127
                  I have the same problem too. But is only in the morning that this happens, when he turn on the machine and start's to work with the scanner.
                  Sometimes instead of giving f111 it gives c550. The strange thing is that only occurs in the first's times in the mornig, and it isn't every day.
                  • tsbservice
                    Field tech
                    • 8030
                    It's power supply, there is bulletin on MR-3018 and e281c but errors are the same. Adjust 5V as per McKinley or replace power supply board.
                    • TTL
                      • Dec 2008
                      • 127
                      thanks...
                      I have another problem with this time one 351c. Inicialy, she crashed some times, and I try to format the disc, was the same, When I change the disc and try to update the firmware, she gave error in update scan. From there when I turn there on she give always F110. I try change the boards, Sys, Slg, Lgc, to another machine, and in the another one she works fine. When I try the power supply, in the another machine she give the same error, and more 10 errors, but to do with a finisher, that none has.
                      I can't try the inverse (change the power supply) for some reasons.
                      I'm now trying to see what's wrong in the power supply but.... I don't find.
                      Can someone give me an ideia.
                      • TTL
                        • Dec 2008
                        • 127
                        this problem it's resolved, I think. But now the machine it's always give "Front Cover Open". I checked the logic cables, format the hdd, new firmware, check the switch in the Cover it's working. but all with no results.
