Embedded Web Browser (EWB)
  • shervin
    • May 2018
    • 9
    Dear Friends;
    I want to setup PaperCut MF in my device which is e-Studio 307 and I cant go further because the device's EWB is disable.
    Please be kind and tell me How to Enable the MFP Embedded Web Browser (EWB) in Toshiba e-Studio 307.
    drugstore-onlinecatalog.com
    • 23010
    Re: Embedded Web Browser (EWB)
    Check that 08-3629 is set to "1", and 08-3641 is set to "1" to be able to view TopAccess.
    • shervin
      • May 2018
      • 9
      Dear Friend;
      Thank you for the response. Unfortunately I am not expert in Toshiba MFP's. Would you please explain it to me in an amateur way?!
        Originally posted by shervin
        Dear Friend;
        hire a tech with a manual or buy one.
          • 23010
          You mean READ?!! I don't think so.
          That sounds too hard. =^..^=
          • shervin
            • May 2018
            • 9
            Dear my friends;
            Unfortunately this device is in IR Iran and there is no Toshiba tech support in this country. I am an IT expert and I do not know about MFP's as much as a technician. So I want you to be kind and answer my question. Your response will be appreciated.
            Kind Regards
              • 8346
              Trying to install Papercut on a current Toshiba copier with current V18 Papercut software with live access to experienced live technical support is hard enough and takes a solid two- three hours with dozens of keystrokes to both the Papercut server and the eBridge Web Browser.
              The task you are attempting to complete with a discontinued copier product, intermittent help from strangers and probably out of date software without the numerous patches that Papercut provides is likely going to be an exercise in futility and wasted time.
              You need to seriously downsize your task and focus on the 1,000 Department Codes that are built into the copier as your solution.
