Toshiba eStudio 4555c
  • bobcap
    • Feb 2012
    • 15
    Any opinions about this machine?
  • clint@clintsimonsen.com
    • 125
    Re: Toshiba eStudio 4555c
    Not a bad machine, runs cheap, make sure it's on the latest firmware etc, make sure the waste box gets replaced and if you hear any squeaking from the exit roller section pull it out and clean the bushes
    Sent from my F8331 using Tapatalk
      • 23010
      I can't improve on that. =^..^=
        • 8254
        It is a discontinued product that had a tendency for Hard Drives to crash. Make sure Super Energy saver is turned on to help reduce HDD crashes and stock a spare Toshiba SED-HDD.
        • bryand
          • Jul 2008
          • 92
          This series has its share of issues, hdd failures, toshiba used self oiling brass bushings ( read self seizing). they are in the exit,transfer belt assembly, bridge units etc. Dev units seize up, bushings need to be upgraded to bearings. Developer dumps frequently in dirty environments. Led erase lamps fail. Adfs have issues feeding certain originals. Other than that there good lol
