Toshiba 456 Firmware
  • gideon
    • 283
    Anyone can help me with update or complete new Firmware for this model?
  • gkalman2004
    • 157
    • gideon
      • 283
      Re: Toshiba 456 Firmware
      Thanks for the info, I got the firmware from Toshiba, and talked to support, hopefully it will solve the problem.
        • 23009
        Did you mention what problem you were hoping to fix? I don't think so. =^..^=
        • gideon
          • 283
          The original problem was soft on/off switch doesn't work, can't prosecute 05 command then it got worst and got "can't recognize cartridge" and I can't execute 08.
          At that point I ordered the system board and logic board, I'll let you know after installation if it fix the problem.
          • gideon
            • 283
            Replaced the system board, it solved the soft switch problem and the 08 setting.
            Still have the error "toner not recognized...". I changed the logic board still error, check the firmware setting it is US (NAD).
            The 2 cartridges I tried are US OEM cartridges.
            The only other option is the interface board or harness.
            Anybody ever had the need to replace those?
            • albenbalinong
              • Sep 2015
              • 30
              Check the contact springs inside the copier touching the chip of the toner. Take it out and clean the contacts inside. Try to pull and straighten the springs to have a firm contact on the toner chips..
              • gideon
                • 283
                I did this and it solved the problem. Thanks
