E-studio 356 F101 8 error code help
  • copiertec
    • Jan 2016
    • 2211
    I went to a Toshiba Estudio 356, today, with an F101 8 error code. I looked in the service manual in section 8 F101- HDD unmounted. I removed the HDD and cleaned connectors and reinstalled the HDD and still have the same error. It stated to perform sector check 08-9072, however, was unable to perform due to time, but, will be back tomorrow to perform.
    I am not too familiar with Toshiba so help would be appreciated. If the sector test comes back good...what would be my next step? Clean MFP and call it a day? If the sector test comes back bad, I am assuming I will have to replace the HDD. What are the HDD Spes? Can I use a non Toshiba HDD?
  • antone
    • Oct 2014
    • 344
    Re: E-studio 356 F101 8 error code help
    Have your self sometime. Replace the HDD! Make sure you clone settings and leave it on customer deask top! Trust me
    Sent from my SM-N950U using Tapatalk
    • copiertec
      • Jan 2016
      • 2211
      I have ordered the HDD. It seems all the updates as far as the lamp, lens unit, wiring, etc have been done, in order for the latest system firmware to work. However, the System board does not have the red dot (or the yellow dot), to identify it, it looks black, it almost looks as if though it was changed at one time. So, I.m hoping with the firmware and a new HDD and following the update procedure it will be good to go.
        • 23009
        Yes: HDD, Firmware, Clone file. Follow the procedure in the manual.
        Some techs will reformat the drive. If it works even temporarily, within 3 weeks you'll be back again. Don't waste your time. =^..^=
        • Vincent128
          • Sep 2015
          • 349
          I don't know what it is with Toshiba and HDD's ..they ate the things like candy...this mornings Toshiba Monthly regional meeting..you now have to have a screen shot of and "NG" using the HDD testing tool to get the drive replaced under warrentee...the drive dies in the copier but then if it's sent in for testing they find nothing wrong.
          Sounds like the copier engineers are having fun at our expense ..again..
          • copiertec
            • Jan 2016
            • 2211
            Apparently, you can only use an ADI HDD, it errors out (F106 0) with the SATA HDD.... BIG price difference! Waiting to hear back from the client to decide whether or not to fix it.
              • 23009
              The Loire Series (205-455) was during the transition from SATA drives to Wipe drives. If the machine you have has a SATA drive you can replace it with a SATA drive. If it has been upgraded to the Wipe drive, all future drives must be wipe drives.
              Loire X (206-456) and Loire 2X (207-457) came from the factory with Wipe drives, and will only accept wipe drives.
              We have replaced very few drives since the upgrades to firmware about 2 years ago. On the 4505AC series I have only replaced one drive ... on a machine that the customer kept yanking the plug out of the wall. =^..^=
              • copiertec
                • Jan 2016
                • 2211
                I first formatted the HDD. Then got the F106 0 error code, read the SM and entered 4 clear sim ( i think that is the one that reads HDD type), and the one I tried to replace it with is a SATA HDD, which in most instances it would work, however, in this case not so. I honestly never even heard of an ADI HDD before this instance, but then again, I do not work on that many Toshiba boxes.
