Estudio 356 with MR3022 message Place doc reader in down position
  • axyun
    • Aug 2007
    • 1323
    Estudio 356 with MR3022 radf. Had just changed drum and cleaning blade and fuser unit due to print quality issues from both units.
    The document feeder was running okay though customer mentioned at times they get a jam or double feed. I cleaned the rollers
    okay and print quality was excellent. Customer called next day with jamming in document feeder. When i got there the document
    feeder said jam in exit area but no paper there. Unfamiliar with this machine and unable to find cause of problem after over an
    hour of troubleshooting. I removed document feeder and took back to my place. There was a dislodged actuator /sensor in turn guide.
    I reinstalled document feeder yesterday and after the usual long warmup there was a message on screen that said "Place Doc Feeder
    in Down Position" I checked both actuators and sensors and they appeared to be working properly. It was close to 5 o'clock and customer
    was closing. Am I missing something because this is stressing me out. Especially after customer just paying me for drum and fuser installation
    which was costly. Please help me here if you can. I would be very grateful if you could. Frank
  • Blizzoo
    • Aug 2013
    • 607
    Re: Estudio 356 with MR3022 message Place doc reader in down position
    Replace the sensor they can be intermittent, check actuator and adjust RADF position/height etc and check in Test Mode for RADF Connection (FAX ON Button 5 [F]) and Platen SW Detection (FAX ON Button 5 [G] Open/Closed)
      • 22997
      Did you disconnect/re-connect the DF while it was live/hot? =^..^=
      • axyun
        • Aug 2007
        • 1323
        I am almost certain I did not disconnect while machine was on as I am aware it
        could cause problem a board on some machines.
        I was thinking about this logically and I assume as on all machines i have worked on
        that you can lift adf and run copies all day long and not get message to place document
        feeder in the down position. Is it referring to something other than the sensors that engage
        when feeder is lifted offf the glass and place back down on glass?
        Thanks Blizoo. I I have the SM but when I checked test mode I did not see a detailed explanation of accessing
        specific things for testing . Just the 2 digit (03) for testing and general info. Is it easy to follow once the
        test mode screen comes on? I am unfamiliar with machine other than having change drum, blade and fuser
          • 22997
          In 03 Mode you can test each sensor individually. It's not simply or intuitive like Kyocera's sensor test or motor test, but I am confident that you can figure it out.
          You'll set Fax to ON or OFF as needed, then select the numbered group that has the sensor you'd like to test. Press Start. You'll see A B C D E F G H, when the sensor is tripped the appropriate letter is highlighted.
          • axyun
            • Aug 2007
            • 1323
            The original detect actuator was activated though no paper was there. I did not notice that it was not in position as it was not obvious and was concentrating on potential problem with radf position on platen. okay now. Another embarrassing but learning moment. Thanks to all for your input. Frank
