Client says MFP flashed on and off during a print job, they removed the paper jams but MFP says to close front door.
1) I made sure all door switches for front door are in place along with actuators located on the front door as well as the side and duplex doors.
2) I disconnected the small switch on the front door (left hand side) and used a wire loop to complete the circuit...still same error. When I actuate the right switch on the front with door open, I hear fans turn on so I think that switch is working.
Any ideas?
Any ideas?
