E studio 477S, re branded Oki. E130 jam
  • Thayer
    • Dec 2017
    • 107
    I have Es 477S giving me random E130, never a paper to remove just open door and close.
    Sometimes it feeds 50 sheets then jams, other times 2 then jams.
    Just installed new cassette assy, that other tech ordered. Tires are also new in feed.
    My temporary work around is all jobs going to bypass, has not jammed yet!
    Manual says check/replace "sensor lever", I could not find such a part. I have ordered the feeder assy register.
    Anyone seen this issue or know this part???
    Re: E studio 477S, re branded Oki. E130 jam
    did you try blowing the tray/feeder sensors out?
    also can u watch feed progress from back of tray? hesitation ? slip? FTF?
    clean out sensors.. now many total pages?
    then lube shafts with TriFlow oil
    check tray guides..
    paper loaded properly and correct size?
      i hated ALL Tosh engines Oki used.. just my 2cents
      • Thayer
        • Dec 2017
        • 107
        Phil
        I did blew out sensors, adjust paper guides.
        I did not try to watch it feed, but I will when I return.
        Meter count 221000 +
        • gliderider
          • May 2015
          • 131
          Check that the sensor flag that sits in the paper tray cavity only pivots in one direction. If you can toggle it back and forth then it is broken. There is a small stop on the assy. that keeps it from toggling in the wrong direction. I had one that drove me crazy with intermittent jams until I removed the sensor and flag assy and looked at it. It should only move back to 90 degrees and stop when actuated.
          Andrew
          • Blizzoo
            • Aug 2013
            • 608
            Sometimes the tray plastic catch located at the middle way inside the tray cavity on the left breaks (it's pushed by a spring) and tray slips out when paper is fed. It can work well when paper tray is full of paper that keeps the tray in place when feeding.
              • 8149
              Phil
              This model is considered disposable at that volume. Time to upgrade the customer to a new e478s.
              • Thayer
                • Dec 2017
                • 107
                Update...I messed it up good. Replaced registration assy, crossed some connectors. some connectors not seated right
                Going back today with pu board, TR assy front and head FFC. I didn't have a good day yesterday.
                Customer stated new machine was ordered but thats all she knew.
                  • 22999
                  Hooray for that! Good luck. =^..^=
                    • 22999
                    I'm posting the photos for Thayer, but I'll let him fill in the description. The part I can see, is that there is an idler wheel missing. He can tell you more:
                    • Thayer
                      • Dec 2017
                      • 107
                      Thanks Blackcat4866
                      The missing idler wheel push's on the lever in the 3rd picture, and keeps the paper tray in up position. The idler i believe is attached to whole feed unit. A project I don't want to attempt. Customer "says new machine on the way"...
                      With the missing the idler wheel, I believe it doesn't keep enough pressure on the lever and the cassette does fall after some copies/prints.
                      I removed the spring from the lever, the cassette raises and lowers as it should. No Jamming after this spring removal.
                      The first picture is a es 287c, also OKI rebadge. We had this one in office for "repair" trying to talk customer into just junking machine. The 2nd picture was the ES477 I was working on.
                      That confirmed the idler wheel was missing and I needed to make a work around.
                      • Blizzoo
                        • Aug 2013
                        • 608
                        Good stuff, never had this particular missing bit problem with these, good to know now and thanks!
