Toshiba e studio 355 Help installing a new HDD
  • olover12
    • Jan 2019
    • 2
    hello I would like to ask how to install a new HDD in the studio 355 since the old one was broken. When I installed the new HDD all it says is cannot start application. Sorry if my english is bad.
    Re: Toshiba e studio 355 Help installing a new HDD
    you will need the: Firmware for the machine.. any "music/video" files and the service manual for the proper procedure.
    • olover12
      • Jan 2019
      • 2
      The new HDD is now installed and working but Now it gives me F110 which tells me its the scanner but whenever I try to install the firmware it just fails
        • 23007
        The best advice that I can give you is to get the service manual, then read the section about Precautions When Replacing HDD. Clearly you haven't read that part. =^..^=
