E-Studio 5540C with C3B0 and C390
  • mntech
    • Aug 2010
    • 250
    Hey,
    Get called out for a CE40 on a es5540c, first thing customer tells me is that the machine may have water damage, after a leaky ceiling....
    I ran thru the procedure in the manual for CE40, and find Y is at 630 in 05-2731 and should be below 628.
    I cleaned the belt sensors, and ran a couple of auto adjustments and 05-2731 was below the 628 mark. First couple test pages I ran in 04-270 looked fine, so I booted the machine and went to run a calibration. Machine codes out with C390 (Cyan abnormality), now when I run 04-270, i get C3B0 (Yellow abnormality)
    Everything looks good on the pages that did come out, and on the belt. So not sure if this thing DOES have water damage, or if I should start with tone control sensors, LGC board, EPU Board.
    I don't fix these machine often so, just going off what the book says.
    FYI, the CE40 went away, and now I just get the C3B0 (happens in 04-270) and C390 (happens when making a copy or calibration print)
    Thanks!
    • 22994
    Re: E-Studio 5540C with C3B0 and C390
    I think the first thing that I would do is print off these originals. Most likely you'll see diagonal voids through cyan and yellow.
    The CE40 pops up when the patch sensors cannot read the color registration patches. And the C380/C390 appears when the patch sensors cannot read the color density patches. You will be able to see the same void pattern on the mag roller.
    If my guess is correct, replace the cyan and yellow developer. Make sure that the developer bearings aren't leaking but they last 1M images or more usually. You will need to go back in and clear the error occurrences ... sorry I don't have that sim off the top of my head. =^..^=
    • mntech
      • Aug 2010
      • 250
      I didn't see any diagonal voids or even light areas on any of the mag rollers, or on the transfer belt patches themselves. I was doing single color sky shots and although the machine would fault out and jam, the partial image on the belt looked solid with no obvious signs of poor developer.
      I did reset the error occurrence in sim per the CE40 troubleshooting of the service manual.
        • 22994
        Have you cleaned the patch sensors? Have you confirmed that the sensor shutter opens? Is the primary transfer belt cleaning properly? I have not seen a bad patch sensor, but I have seen sticky shutters and dirty patch sensors.
        You have ruled out developing as the source of your codes. =^..^=
        • buzz
          • Aug 2013
          • 288
          Originally posted by mntech
          Hey,
          Thanks!
          What was the fix, I'm getting similar, actually C3B0.
          Thx
            • 8479
            An e5540c with water damage is probably worth less than a boat anchor.
            What is the meter read on this copier?
            Give the customer a quote on a new e5516AC and walk away.
            There is little point in keeping useless info in your head about discontinued copiers.
            This model was introduced in 2011 and discontinued in 2014. Toshiba Tec Japan has ended responsibility for all technical support, consumables and parts.
            • mntech
              • Aug 2010
              • 250
              Honestly I never heard back from the customer. So either they found another company to service the machine, or replaced the machine.
              I came across a C3B0 since then, but was easy to diagnose as needing the yellow developer replaced due to diagonal voids.
              So you may want to focus on yellow dev or drum
              -mntech
