456 with C260
  • djs9164
    • Mar 2018
    • 79
    456 with C260
    Have an EStudio 456 that warms up and displays a C260 code. Lamp comes on in warm up and test. Also cleaned optics,white plate and CCD. Any suggestions before I order the lens unit?. TIA
    Sent from my XT1635-01 using Tapatalk
    • 22932
    Re: 456 with C260
    I've been working on an eS357, which does have some differences, but this might help:
    My machine is intermittently copying and scanning "static" pages. Not solid black images, but static, and with image voids. First I discovered breaks in the ribbon cable to light source #1. In addition to metering it out you can check for dimples in the ribbon surface, where the conductors break:
    I replaced the cable, but still got static pages and C260's. Since the lamp was still not lighting and the lamp is powered by the SYS board, I replaced the System board next. While scratching my head, I noticed that when I press the DF closed flag the lamp still does not light, but the display flickers to a "Ready" screen then comes back to C260.
    Since I have never had to replace an LED lamp in a copier, I did not consider that it might become a dead short. While metering out the LEDs, I found the LED at the rear reads 0.372 ohms, and the apparently identical LED at the front reads 0.006 ohms (almost a dead short).
    So my current theory is that the front LED is shorting the 5vdc at the system board. I've got the LED light source #1 ordered for tomorrow morning.
    Now I think the eS456 uses a Xenon lamp, not LEDs, so that may change your course of action. =^..^=
    • djs9164
      • Mar 2018
      • 79
      Re: 456 with C260
      [ATTACH=CONFIG]41774[/ATTACH]
      I will check the cable, but in my case the lamp does come on so it looks like either light is not getting to the CCD or not being interperid properly.
      • djs9164
        • Mar 2018
        • 79
        Re: 456 with C260
        I replaced both the SLG board and lens. No more codes. Thanks for all the help.
