Ricoh tech needing help with 3505AC
  • Hadster
    • Aug 2011
    • 264
    I ordered one of these in to take a look at before I signed on the dotted line to become a Toshiba dealer. It is a lease return with 56K on color and 75k on B/W. If it was a Ricoh I would know exactly what to do but not on a Toshiba. I have the service manual but would like to save some time if I can. What direction should I go with this (attached) image? The left one is the copy BTY. Thanks for your help!
  • Hadster
    • Aug 2011
    • 264
    Re: Ricoh tech needing help with 3505AC
    Bueller? Bueller?
    • guitar9199
      • Sep 2016
      • 1099
      Look into the Automatic Gamma adjustment in your "Image Quality Adjustment: Copying" section of your manual.
      My Toshiba training ended with the 2500C/3500C models, but I'm sure the process hasn't changed THAT much.
      Good luck.
      • tsbservice
        Field tech
        • 7975
        I have no manuals for this model also. Generally speaking guitar9199 is right, do Image Quality Control then Calibration. You may also check here:
        http://business.toshiba.com/download...maging-v01.pdf
        It is an preceding, but very good Imaging manual for older e-Studio 4520C series.
        • Thayer
          • Dec 2017
          • 107
          Go into user functions
          Select admin tab pw 123456
          Run color registration then
          Color calibration, pick calibrate and a internal print will print
          Follow prompts
          Image units come right out the front. Behind the waste bottle
          • lopakad1
            • Nov 2014
            • 69
            Stay far away!!
            • seansbar
              • Dec 2010
              • 198
              Originally posted by lopakad1
              Stay far away!!
              • lopakad1
                • Nov 2014
                • 69
                There okay I'm just not a big fan. We ordered a couple brand-new and he came in damage right in the box. How to get them replaced. Then the problems I have is with their support and the fyi website it's old and antiquated and out of date compared to the other brands we take care of.
                I guess my problem with Toshiba is getting help on the back half when you do have a problem.
                I guess I'm very biased because we purchased 10 of them and seven have weird problems and it seems to me that they don't come up with fixes just firmware or software updates.
                  • 22997
                  If you print these pages then scan (or preferably photograph) the results, I can offer an opinion:
                  • Hadster
                    • Aug 2011
                    • 264
                    Thayer was spot on! I figured it would be something simple for you guys as this would have been for me on a Ricoh. Like all of you, I am crazy busy and just haven't had time to go over the manual yet so again I thank you for saving me that time. I promise I will read the manual this weekend to not waste everyone's time on something as simple as this in the future!!!!
                    • Ketchup
                      • Jan 2019
                      • 18
                      You have a point, but we are not having issues with new ones, its the pm time 8508/7605ac developers. The devs are leaking and destroying the gears/seals, some way before pm. Toshiba bought and paid for company boys do nothing but "send us all your data and the destroyed units"....here's an updated wire scraper and front block-NOTHING to do with issue, plastic is crap, these are a fail compared to the 6550/6570 developers. You get nowhere reporting it, you do all research and development and TABs wants you to send the info.
                      Then they release the 8518a/7516ac with the same dang problem.
