toshiba es 556 duplex
  • pontiac
    • 420
    When using duplex funtion the paper drops straight down in duplex tray i thought maybe door was warped and swapped same problem i checked both door sensors ok no problem with one sided print or copy. thanks for replys
    Re: toshiba es 556 duplex
    Originally posted by pontiac
    When using duplex function the paper drops straight down in duplex tray i thought maybe door was warped and swapped same problem i checked both door sensors OK no problem with one sided print or copy. thanks for replies
    check the switch back assembly...
    maybe a solenoid isn't firing
    any error codes ?
      • 23009
      jam codes? =^..^=
      • pontiac
        • 420
        Thanks for reply. We swithced out the complete fuser transfer drawer.and solved issue . The plastic transport section under transport belt had a crack.
