Close front cover studio856
  • jvargas
    • May 2009
    • 44
    [Electrical] Close front cover studio856
    Hi, I have a TOSHIBA STUDIO 856, Suddenly appear this message "CLOSE FRONT COVER'' , I changed the power supply and the copier is good. My question is somebody now Where is the problem in the power supply. I check all the fuses and they are goods. THANKS FOR HELP ME.
    6LG04279000 THE NUMBER OF PART LIST OF THE POWER SUPPLY
  • lazymangr
    • Feb 2017
    • 115
    Re: Close front cover studio856
    hello! where you read to change power supply?
    check that the right side door closing properly of if there is any part broken that actuates the switch to detect that door is closed. its like a finger on the right door on front side.
    • jvargas
      • May 2009
      • 44
      I am a technician. I change the power supply. And the copier is working again. But i need to know how to fixed it
        • 23008
        Simple:
        Place PS in a box.
        Ship it to Hytec.
        Pay the repair fee.
        Hytec ships you back a repaired PS.
        • Edward
          • May 2019
          • 32
          power supply will not cause that close door problem, When you replaced the power supplly you accidentally fixed you problem. Power supplies 120v to fuser and transforms 120 down to 5dc, 12, dc, 24dc. Thats all. You close door is a 5v sensor
          • jvargas
            • May 2009
            • 44
            I am going to check 5v. It is lost
            thanks for your help. 👍
