ES 287 csl
  • coachjillm60
    • Feb 2013
    • 7
    ES 287 csl
    Machine blurrs and smudges intermittent!
    Replaced transfer belt and black drum still happens.
    It seems trail edge smears with a grey smudge on edge of page . Thanks for any thoughts Jim
    • 22997
    Re: ES 287 csl
    I seem to recall the fuser becoming difficult to turn, causing compression blurs and paper jams. Setting the machine to heavy paper media type temporarily allows paper to pass, since it slows the print speed. =^..^=
      • 8144
      Re: ES 287 csl
      Make sure the 4 LEDs are clean. One minute job with a tissue.
      • coachjillm60
        • Feb 2013
        • 7
        Re: ES 287 csl
        Thanks for input ! Yes LED,s are cleaned and as I saisbits inttermitant ! I am leaning towards fuser also like black cat said , I will do as he suggested as a test and change paper media stettings! Thanks again..
          • 8144
          Re: ES 287 csl
          The now discontinued e287cs/ e347csl series proved to be very problematic with regards to Service Dept reliability and profitability.
          You should be dropping heavy hints to the customer to make plans as soon as possible to upgrade this copier to a new e389cs.
          • rspicer
            • Oct 2015
            • 97
            Re: ES 287 csl
            I've seen this quite a few times with that family of machines. It was always the fuser.
            • antone
              • Oct 2014
              • 344
              Re: ES 287 csl
              duplex jam 520 paper stops under drum
              Sent from my SM-N950U using Tapatalk
              • Vincent128
                • Sep 2015
                • 348
                Re: ES 287 csl
                That fuser will only go 30K to 60K rather than the 300K its rated for - causes all kinda of jams and quality issues.
                the best way to fix anything in that entire series is to toss the machine off the roof of a very large building.
                • djbass
                  • May 2008
                  • 159
                  Re: ES 287 csl
                  To be fair it is a re branded OKI printer so not entirely Toshiba's fault. I always thought this series was ok apart from being somewhat messy inside and the ADF jam access cover always grinding about mid-life.
                  No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
                  • Blizzoo
                    • Aug 2013
                    • 607
                    Re: ES 287 csl
                    A fun to replace the base plate - where the tray 1 goes in
