4505ac
  • antone
    • Oct 2014
    • 344
    4505ac
    Trouble code C553...does one have this problem! I reset all connections the first time and it went away....lasted a month!
    Sent from my SM-N950U using Tapatalk
    • 22999
    Re: 4505ac
    Are you sure about that error code? It doesn't show up at Printers Copiers Servicing - Reference Manual. under any Toshiba model. It makes me think there is no C553. =^..^=
    • rspicer
      • Oct 2015
      • 97
      • arnh79
        • 468
        Re: 4505ac
        There was a bulletin about this issue shortly after the MR-4000 was released. It's caused by damage done to the board on the DSDF's CCD module. The fix is to replace the entire module with the updated version. I replaced several of these under warranty in the first year.
        Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
        • Toshitec
          MFP Engineer
          • May 2011
          • 22
          Re: 4505ac
          The fault is created by the CCD unit in the DSDF document feeder but can also damage the SYS-board (most common). I had this problem two times with different machines.
          Be carefull to replace one at the time, because one can destroy the other. Good luck!
